silentscreamer
- 106
- 1
- Oct 11, 2008
Moncton,
NB, Canada
i have a 1996 tsi awd with lsd rear diff that i am parting out, its completly gutted at the moment so anything you need will be easy to get at.
i also have a black dash, airbag, centre console, e-brake handle, tweeters.
i have a 2ga 7 bolt block work of parts and a 6bolt block as well (heads internals everything are in rubbermaid bins in storage.
i have a large list of performance parts as well:
6 bolt Eagle knife edged stroker crank. Never installed, coated in assembly lube and wrapped for storage. - 600
6 bolt Manley 8.5:1 stroker pistons, new in box expect pistons have been coated in assembly lube and placed in ziplock bags for storage as well. -375
6 bolt Manley h beam rods n.i.b. - 225
Kiggly main girdle - 150
Arp main studs, torqued once - 60
6 bolt Acl rod bearings, n.i.b. -35
Enginebldr 1mm oversized valves, all 16 -125
Evo beehive springs and retainers, all 16 - 80
Fluid damper - 200
Aem cam gears - 175
Brian crower 280 cams - 180
Revised 3g lifters - 50
Bosch 1600cc white top injectors - 200
Black case 98-99 ecu c/w tactrix cable - 250
Calan dual catchcan dual 1" npt inlets on tops sides, 1" npt outlets on both sides, viewing glass, drain ball valve, mounting bracket - 200
Q45 throttle body, parts of what looked to be cruise control or idle air control has been shaved off, repainted VHT aluminum - 150
Stock valve train for 2 different heads, 1x1g nt/1x2g t, (rockers, lifters, valves, keepers, shims) - offer
1gnt throttle body all sensors included - 50
2gt throttle body, all sensors included - 50
Knock off hks oil cap - 8
Non cracked/shaved valve cover, painted black with 1/2" npt bung welded on vent side, stock pcv valve threads - 50
Topmount, divided, t4 flanged, dual 38mm wastegate outeler, power steering has to be removed, alternator relocated. Compressor should face the drivers side for clearance of larger turbos - 400
2x tial 38mm wastegates – 75 each
Holset hx40, 7 blade, with divided t3 and divided t4 housings, modified dsm 1g wastegate actuator - 300
Boston hatcher 2g rear differential mounts, tab has never been welded to the subframe - 175
Knock off apexi n1 exaust , slant cut - 35
Saturn alteranator, 1 year old - 25
Symborski shifter bushings - 30
willing to ship from moncton at buyers expense, paypal fees covered by buyer as well.
Fluid damper - 200
Aem cam gears - 175
