FASTSPOOLINGST
- 598
- Sep 17, 2003
Elizabethtown,
Kentucky
I have posted this in problem diagnosis probably 2 times and yet, no one can answer my question.
i get a check engine light, so i hook up the OBD II tester, and it says
Oxygen Sensor (Bank 1 Sensor 1)
Does this mean that my O2 housing O2 sensor is bad, or the one by where the cat used to be. Because on my turbo timer I am reading O2 sensor voltage. I am also getting the same gas mileages as before it popped up. The weird thing is, that after the car is warmed up for a while, if you shut the car off, then erase the fault code, you can then drive it around all day and the light will not pop up again. It will only pop back up after the car has been sitting over night or for a few hours to cool down. What gives? someone help me asap please!
Thanks in advance
Thanks in advance
