BOOSTED4LIFE90
- 105
- Aug 30, 2003
Anaheim,
California
Hey fellas! I got a big problem i recently installed a 3'' o2 and a 3'' downpipe with a Turbosmart 35mm external wastegate and could'nt control boost right after installation.I thought it might be my mbc but that was not the problem,no matter how i turn it it hits 20+psi.So i connected the vaccum hose from the turbo to the lower nipple on the external wastegate and no luck still hitting 20psi so i hooked the vaccum hose from the turbo to the internal wastegate and still no luck.I got no boost leaks,i know that.Could it be that my wastegate actuator arm is stuck open?If it was shut closed it would'nt build any boost and if it was stuck open it would build mad boost right?I tried to move the wastegate actuator arm and it stuck sideways,i tried to straighten it so it can face down but it goes back sideways.Could that be my problem if so how can i fix it with out having to buy a new actuator arm?Should i take it off and turn it some how or what?I really need your help guys.My car runs fine but i cant go full throttle because it hits 20psi and then i let of the gas.Any help would really be appriciated.Later and thanks!
