nazthug
- 478
- 8
- Dec 24, 2003
livermore,
California
i keep hearing about how you should upgrade your pump at least if you do this and that for mods, whatever they may be
i come from some experience with fuel tuning on my previous car(focus with t3.04e turbo and pectel t2 standalone) and was just wondering.
If you are keeping the stock fpr and just upgrade to say a walbro 190(which i am getting) how does that give you more fuel?
Only thing i can think of is unless with more boost(say 18psi, with stock 1:1 rise) thats 18psi more fuel, so 43+18=61psi of pressure, and the only thing i can think of is that the stock pump cant supply that much? Is this why a bigger pump helps with fuel even if done by itself? Or do you guys mean upgrading the regulator just not saying it in your posts??
I just bought a FP big t28 and so far im stock for fuel, but i just ordered a walbro 190lph.
I also have an injen intake, rre uip, greddy type s, thermal 3" catback, 3" downpipe with 3" cat, evo3 o2 housing and POSSIBle might order an evo exhuast manifold as well
STILL on a stock SMIC
I know i will have to eventually get 550cc and an afc(big step down from using a standalone before,
) but whats this talk about the fuel pump being at least somewhat of an upgrade?
How much boost can i run on the t28 with just a pump???
Also, another question, how can i get to this lower, safer boost until i get some fuel?? I have a profec b right now with the above mod(stock t25) and just cant get it below 15psi and i have it directly hooked up, no bcs, just compressor nipple, greddy, greddy, wastegate
) but whats this talk about the fuel pump being at least somewhat of an upgrade?How much boost can i run on the t28 with just a pump???
That is what I use. The WB logs AFR and RPM, I can then go back with my data logger to check timing just to make sure.
