Assembling my own turbo...
jake98gst
433
Jul 17, 2003
St. Louis Area, Illinois
I see a 7cm turbine housing is $175 from SBR. Where could I get some kind of 16g/Big 16g/Evo III 16g compressor side only? How hard would it be to put together or install? Anything else I would need? How much would everything but the turbine housing cost? I'm just trying to save a buck or two. Any other comments thoughts are appreciated.
Thanks,
Jake
It would be to your benifit to just buy a real turbo instead of trying to assemble your own. What happens if you screw up puting on the comp housing and cause the wheel to go digging into the aluminum and send shards into your engine. Just spend the $500 and get an already assembled turbo.
I would suggest buying from FP, they are very knowledgable and actually warantee their stuff.
