Coldandafraid
- 1,147
- 3
- Mar 1, 2003
Edmonton,
Just finished installing GM maf... admired my handywork for a few mins, and then took for test drive.
I was concerned with the translator to wire harness connection because the translator plug is so differently shaped, but my afc, and my pocketlogger were getting an air reading, so I assume all is good.
The car is all warmed up now. So, I drive. And now, whenever I drive (or rev the rpms higher than idle) and then take my foot off the pedal, the car drops to around 500 rpm and has a hard time idling for about 5 seconds and then it recovers and idles normally. But, its a blow thru maf, and it happens whether I have just been boosting or not.
I left all MAFT settings at zero, and left all AFC settings were they were. Pocketlogger tells me at low-throttle, my trims are atill balanced at all rpm points, except at idle, which is 750, (below my first increment - 1000) the car is adding quite a bit of fuel.
So, is it a simple case, of my car being too lean at idle... or something else?
ok, it was just a theory...
