kilurv8
- 279
- May 7, 2002
Huntley,
Illinois
I am new to the external wastegate style of boost control. I have avoided going to one due to cost constraints but I have decided to bite the bullet and switch. I recently aquired an Extreme 2.5ss o2 housing dumped and a tial 40mm gate with a 1bar spring. My boost controller is an EVC EZ.
Now I have read in a couple different places that if you run the tial on a 1 Bar spring, it is only supposed to give you just under 2X the spring pressure for the max amount of boost. So if this is true that would mean only 25 to 26 psi. Now I am looking for some real world answers from people that have run 30+ psi successfully on a tial with an EBC and what springs they have. Or if you know if this is true.
I also do not know if this matters based on if you use just the side nipple and run like an internal gate or use both and run it properly with the EBC?
, use a pair of clamps to help hold the bi*** down. It definitely helps A LOT to use clamps when putting it back together.
