boost creep
ineedacar
30
Sep 8, 2002
westerville, Ohio
ok i got boost creep on my 14b like crazy...i have my boost set @15psi and once i get to about 5500rpm or so it jumps to 19 or 20 and then fuel cut...my question is, should i port my wastegate hole some or just buy a 34mm flapper? or do both? and also i heard that if u upgrade to a 34mm flapper it could prevent me from hitting more boost once i turn it up, so is this true or not
thanx
josh
the 34mm flapper just allows you to port MORE. You will definitely have to do some porting to get rid of boost creep.
If you haven't already, port around the flapper so the arm can open the entire way. I was having the same problem on my car and I did a little porting and polishing of the wasteage hole and opened up around the flapper arm and I have no creep issues now.
