soul
- 68
- Sep 16, 2002
Macon,
Georgia
I did a search but no luck ;(
I'm getting everything off my car while I'm waiting on my install kit. The only thing I don't understand about the install is the water lines. Do you install the water lines like they were from the t25 and then swap the rubber hoses (every vfaq i read says you have to swap the feed and return lines). Thats where i get confused...do you swap the hard lines or the rubber ones....i read about needing some 3/8 line to extend one of the lines so it will reach. Sorry if I seem so lost. Thanks.
I'm assuming you run them like in the pitcure i attached and just swap the rubber lines. Thanks for any help.
