greddy universal flange?
Onnipotente
105
Oct 16, 2003
im planning to get the greddy type s blow off valve and came across the greddy universal flange... would i be able to use that instead of getting a new upper intercooler pipe?
Depends on the material your using on your car. If you have a steel pipe where your stock IC is attached to and your Greddy flange is steel then yes you can cut it off and weld on the new unit.
If your pipe is plastic and the flange is steel or aluminum etc.. (mis matched materials) then no there is no way. Steel to steel, aluminum to aluminum, nothing to plastic as it wont hold the pressure.
If you have a 1G BOV on your car now, you can just re-drill the flange you have and put your Greddy bov on it. The flange is exactly the same except you need to drill 2 holes a little closer together for the greddy to bolt down. If that's the case, it's a 30 min install no flange needed.
if i want the bov to recirculate to the intake... do i have to change or do anything to the intake pipe? (everything is stock)
    • eclipsemf
