laser92awd
- 128
- Jul 13, 2002
Central Florida,
Florida
I am in the process of upgrading my intake and fuel injectors. While I was at it I got the B&M Commandflo regulator. After hacking off the end of my regulator as per instructions and trying to keep the spring and o-ring in place while screwing it all together I kept thinking "rinky-dink" in my mind. So now that I have it together I'm a little paranoid.
The regulator accepts pressure, not vacuum, right? Or is it the other way around? I attached a hand pump to it and when I pump it I can hear air coming out around where the adjustment screw is threaded in. Is that bad? Should I teflon the screw?
Also I can't remember where I got my upgraded intank fuel pump - it was so long ago. It is an intank pump and is either the 3000GT pump from DSS or the pump Dave Buschur sold back around January 1995. The question I have is what is the maximum pressure I can safely run on whichever pump I have. I understand the base fuel pressure + boost = maximum psi needed from pump. So if I set base at 43psi and a maximum of 22psi on the turbo will my pump handle the 65psi required? (That's only 7psi higher than what I've been running already)
Any suggestions would be appreciated!
