1g stock cams w/ stock 1g cam gears in a 2g head, which set of stock cam gears?
FearceDSM
137
2
Nov 18, 2003
State of, New Jersey
I have a set of 1g cams with the cams gear still on them. I have a 95 gsx with a 2g head that I would like to install them on . The only difference on the cam gears is that my stock 2g intake cam gear has some sort of round metal plate attached to it. My question is do I need to use the stock cam gears from my 2g with the 1g cams or could I just swap out the whole setup? Another question, I am also swapping in a 1g throttle body, what kind of gains would I be looking at? Any input would be greatly appreciated.
You will want to use the 1G cam gears with those. I don't know what you will notice on the TB, but I know a lot of people who swapped to the 1G cams and they all noticed pretty good improvements with them.
  • For sale 4G63 Pair of fog lights
    Pair of Fiat 500 fogs. Complete with mounting brackets and hardware. Both lens are in really...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
