tacoman123
- 36
- Jan 1, 2003
Yes, I know this might have been talked about before, but I have some questions.
I found both a 95 AWD rolling chassis, and a 91 Eclipse AWD.
The 95 has no motor, and I intened to put in the 1G 6-bolt. I was wondering, what wiring harness do I use? Will the interior (dashboard) wiring harness work with the 1G engine wiring harness and 1G ECU?
Will the AWD trans from the 1G bolt onto the 2G? Transfercase? Rear differential?
Are the suspension parts similar/same between the two generations?
Thanks
~Tacoman
Thanks
~Tacoman
