Cablefed
- 209
- 2
- Oct 23, 2002
I need to check my base timing on my car that now has a 6 bolt. I'm aware of a certain plug on 95's and 1st Gens that have to be grounded to set the timing. As for the 2g's that don't have an adjustable CAS I'm not aware of anything that needs to be grounded. Now that I have the 6 bolt is there anything on the ECU I need to ground to set the timing with? I have a pocket logger so that should help me with what I'm seeing from the ECU side. This is my first timing adjustment so I'm a little stupid on the subject. Any help would be appreciated. Thanks.
