1FAST2G
- 138
- Sep 19, 2002
La Puente,
California
Can you hot tank a block with the rods and pistons still installed? Everything else will be stripped from the block.
Originally posted by CycloneAWD
Np pressure, just dipped...as far as where to obtain said acid...I have no idea...but a local auto machince shop should have facilities to do it for you...or MAYBE...get you info as to where to do it yourself if you really wanna...But I truly don't see why you would wanna do that yourself...I mean locally here, its like 30 dollars to get a hot tank done...So I mean let them do it...less hassle you know??
Originally posted by 98TsiAWD
I would not Hottank a block. Cast-Iron is porus. Do you want all that acid in your motor oil later on?
Use some elbow grease and do it yourself.
