Whats The Deal With Those Cyclones?
dsm-jdm
44
Oct 8, 2003
Can you install the cyclone in take manifold in an american 4g63t and have it run the dual bufferfly system properly? ( Assuming you have all the electronics right for the bufferfly valves)
its a dual runner intake manifold, i think it actually flows a little bit less air then the usdm 1g intake mani, but it has the dual runners so you get low and and top and
my advice, is not to waste your time with it, save some money and buy a magnus intake mani, you wolnt regret it
the cyclone will bolt up, but its not going to give you any amazing increase in power, but its a decent upgrade i guess
Originally posted by jdmawd
They are the shit, i have a mint one you can have for $75.
Sweet dude...Thanks for the offer....I might take you up on that..But first i'm purchasing an 4g63t from a 2g eclipse..wil lyour cyclone intake manifold fit on it? Also, im asumming you have one installed on your 4g63, how much of a difference does it make? And how difficult was the electronic wiring for the proper use of the bufferly system?
nope you need a 1G head and throttle body also. i have those 2;)
hahha, funny!
Im guessing that fits on the 2g 4g63t......Was it difficult to install the eletronic wiring for the proper use of thee butterfly system?How much of a difference did it make on your car?
never used it you need the jdm ecu also my motor cant handle cyclone power.
Couldn't handle Cyclone power???? Why????
the manifold is to awesome it makes to much power down low.
yea funny...thanks for the pulling the chain....:|
dont waste your time with it..
its says CYCLONE, WHOOPIDY DOO!
other then that i wouldnt waste your money.
If you can set up the actuation, it should broaden your torque curve a fair bit.
However, they're not widely run, they're not sought, so apparently either it's too fussy to set up properly, or there's some other failing.
