Fuel rail capability
hmm, its probably less about volume and more about pressure.. keep the fuel pressure high enough so that the injectors surge cannot temporarly lower the volume of fuel and you should be ok..
as long as you can get enough fuel to the rail. i doubt you should have trouble.. make sure the pump and lines can flow enough, and keep the pressure up.
