My Motor i'm building How much horse
Status
Not open for further replies.
semperfi221
Sep 19, 2002
canton,
This is the list of parts that i'm building my motor with tell me what you think, how much horse do you think it is capable of,
Djon tool intake
buschur racing exhaust
buschur racing downpipe
turbonetics t4 manifold
buschur racing o2 housing
boostcontrol hks evc
apex super afc
walbro 255lph fuel pump
hks 660cc injectors
B&m command flow fuel pressure reg
garret t4 turbo
greddy external wastegate
dejon tool fmic street kit
greddy type-s bov
magnus motorsports intake man
extreme turbo adjustable cam gears
hks cams
unorthodox ultra ss 3 pully set
arias racing pistons
eagle rods
mitsubishi 4 layer metal hg
ffwd connecyion butcher crank
fluidyne radiator
bushur racing head
bushur racing block
nitrous expres direct port nitrus injection
venum fuel rail
aem engine management system
act 2600 clutch kit
act flywheel
kaaz front limited slip diferential
you do know of course there is no right answer to this question.
My estimates would be anywhere between 0-500hp. give or take 200hp.
actually i just read a lil further into your list and alot of that stuff makes no sense.
my advice to you is do more reaserch before you start buying parts.
you need to research alittle more.
Your going with a T4 yet your only using 660cc injectors. Take that b&m fuel pressure regulator off the list. You might as well get the fuel injector clinic fuel rail and run -6an through your whole system with a real fuel pressure regulator. With a turbo this big you might want to go with a race core instead of a street core. And you will need something better to tune with than a afc.
Agreed, except he has an aem standalone on his list.
I wouldnt run a T4 if I were you, get a T3/T4 of some kind. But logically with good tuning and a few slight changes to you list and you should put down anywhere from 400-500whp If I had to guess.
Closing this thread before the flaming begins, trust me it always does with questions like this.
Status
