Throttle body vacuum lines
Kingdom
366
Jul 19, 2002
Adliya,
OKay. I am having a very hard time getting my idle right.
I changed 2 ISC motors and still cant idle right, and I dont have a scan tool to let the stepper motor stop half way to adjust the BISS screw.
so I decided to use the JDM throttle body that came with the 6-bolt motor. the thing is that the JDM throttle body only has one vacuum nipple instead of four, and I am using two that go to EGR solenoid with the other two plugged off.
What I dont know, is that on the old throttle body does it matter what vacuum nipple u actually used for which line. I mean if I had a stock car and I switched around the vacuum lines on the throttle body will it make a difference? are some restricted more than the others etc?
I just want to know if I can have a T for those two lines that I am using to go to that single nipple on the JDM throttle body?
alright I understand now. I had a look at the throttle body and blew threw the ports, all four. two are just boost sources (A & A1) then the other two, E is a tiny whole before the butter fly and the P is after the butterfly.
so I guess I cant use the T as I thought. probably just gonna cancel the whole godamn EGR and live with the CEL.
Thanks anyways, learned something today.
I need some info on the 90 TB, which one of the ports are vaccum, pressure or vaccum and pressure? The ports are old and they aren't solid, what i mean is that if i move it the rotate could this cause a leakage or something. Thanks
