jdmawd
Banned Member
- 3,318
- Mar 20, 2002
GreenBelt,
Local dsm shop owner had his bolt-on evo8 dynoed up a Altered atmosphere in gathersburg today here are the results
Originally posted by Flat Lined
Not shabby, have you noticed a noticible difference with your kit?
48 whp on a bolt on EVO 8 is definetly something to look at
If my memory serves me he still has a stock intercooler. If that is the case then it definitely makes sense. Get a turbo blowing nice hot air and cool it was down with the sprayer. I would also theorize if he had a 216 core on there he wouldnt have seen the same improvements because the IC core wouldnt have been all that hot.Originally posted by jdmawd
Originally posted by DSMTurbos
those are impressive numbers none the less. jdm do you plan to dyno with nitrous and without to have a similar compartrative on your car?
i personally would not run N20 for two reasons. 1 its cost more to fill and 2 my filter sits right next to the intercooler. would not want any N20 to get sucked into the air filter.
..Originally posted by DSMJim
I have an ntercooler on my car, but I also have a slightly shorter version of a 216 (28 x 8 x 3.5) and when I used my ntercooler at the track I didn't notice any difference in my 1/4 times.
I think it's partly because my intercooler is so large it never really gets hot anyways.
Originally posted by greyforestgst
well of course a ic chiller is going to rock ####ing hardcore on a dyno, there's no air moving through it![]()
ive been thinking about making my own co2 kit using paintball hardware, and making my own cooler bracket...
That really didn't make much sense. That's like saying your car would be just as fast in 110* heat as it would be in 60* heat. because of the size of you're intercooler.
I have an intake temp gauge in my car ill have to see what the charged air temps look like while spraying the core, the rest is tuning.
I dunno...
I would agree with you Jim. A 216 sized core will probably make sure the intake temps never get above ambient. Combine that with a larger turbo that isnt WAY out of its efficiency range and I doubt you would see a big gain when the temps go up 20 degrees or so. Hell I ran a 126 trap on pump gas on one of the hottest days of the year. That doesnt mean I could go back now and run a 130 on pump gas. At least I dont think it does hehe. However in the case of an Evo where you have a decent size IC core and a turbo running out of its efficiency range its not a big shock that it picked up all sorts of power being brought down to temps at or below ambient.Originally posted by DSMJim
It doesn't make sense to me either I would think it would help but what I figure is my intercooler at the end never gets hot even in 100deg weather the cooler end tanks on the cold side are still cold even without the ntercooler so Its just not making enough of a difference on my car to show on my timeslip. If I had a really small intercooler which heatsoaked then maybe it would help.I dunno....
. We discussed this on the old Talon Digest.
