Cam question
HBM4G63
84
Jul 15, 2002
I just rebuilt my engine. I also ordered a knife edged crank, and a balance shaft elinator kit, and hks cams 264 / 272. I have a Kand N, buschur full exhaust, and hacked the maf. Stock everything else. I have not put my engine back together. Can i put the cams in with almost everything stock? Should I also install the new crank and balance shaft elimator? Should i wait to ungrade my turbo and other things? I dont have the money for a turbo yet or an intercooler. I will be buying the br-57 and a indy race cool intercooler. I also have to buy a s-afc, boost controller, and a egt gauge. but what are your opions on installing them right away(cams, balance shaft, or crank)?
Thanks
please do the balance shaft eliminator kit. that way i don't have to read a post from you later saying your bal belt took out the timing belt and ruined your head. also if you eliminate the balance shafts there are less bearings to spin out :D
i dunno about the other stuff
