CBgst
- 582
- Jun 25, 2002
I'm buying the t3/t4 set up from dsmotorsports, feul pump, clutch and egt gauge for now( that's all I can afford now) But anyway I will be getting injectors, fmic, and an afc as soon as possible but my question is can I just run low boost for now say 16psi until i get the rest of the mods or at least until I get afc. Or should I just hold everything until I get the other stuff. I would like to at least put the turbo on but don't want to break anything. As long as it doesn't creep shouldn't i be fine for the time being. I have a boost gauge so i can watch for creep. Oh by the way I'm running 16psi now anyway it just doesn't hold to redline and the new turbo will but will that hurt the car with out the mods i mentioned. Running the same boost I should see some improvements though right? Do to the more efficent turbo ( at 16psi) and it holding to redline?
