vassil
- 82
- May 22, 2002
Winona,
Minnesota
Hi Guys,
I searched found some info but would still like to ask a question. I just installed a TIAL BOV on my DSM. I was hesitating b/n the HK$ SSQV and the TIAL, and Nate @ DS Motorsports talked me into the TIAL. I run the DSM MAF translator (blow-thru). I get some major flutter @ low boost/regular street driving. I figured that there are 11 & 15psi springs. My boost is set @17lbs and even on 3rd gear pull when I let off the gas it still flutters (no compressor surges), not as bad as low boost, but it is annoying. Also the BOV is mounted upside-down ... dunno it it matters... Do you think I should go with the 9lbs spring, or should I bail and get the HK$ SSQV. My car is primarily daily diven and will remain that way.
Any input will be greatly appeciated.
Thanks in advance,
Pics of install:
http://www.mndsm.com/gallery/TialBOV-Install
Thanks in advance,
Pics of install:
