CH152
- 296
- Oct 8, 2002
Lexington,
Kentucky
I was not really sure where to post this thread but i guess that this is a decent spot. I have been threw a sh!t heap of sh!t with my car. 2 blown motors and a Crankwalk for the last time. I wanted to sell my car after every little incedent but i figured that i would keep trying and maybe i could get something right. I always crossed my fingers when i would start the motor up... Anyhow, after the crank walk problem... I decided hell one more try with the 7 bolt huh.. I'm crazy right? Well.... Heres how to tell you the truth i think i fixed a problem... Most people would agree on this about bad machining of the crank, poor oil galleries, miss alignment of the thrust bearing. I used the original crank from the 98 engine with a 92-99 7 bolt block some where in those years. The original crank was so messed up on the rod journals, that we had the crank machined down 20 thou on the rod jopurnals and 10 thou on the crank journals. We plastigaged everything to make sure that we had oil clearance. We put it back together all bolted up with 3 thou end play on the thrust bearing. 6000 miles later 12 pulls down the track and to my suprise today the Clevitte 77 bearings we used, the endplay was 3 thou still, i could not believe it. I could have been for certain that maybe it would have increased some... It stayed the same... But my DSM days are coming to an end, in total mods 8056 dollars have been spent, i am selling my car for a 2000 F-250 diesel work truck... Whether or not it would be something that fixed my crankwalk issue, as from what i can tell it did... Just giving you DSM'ers something to think about with 7 bolts.
always a DSM fan
always a DSM fan
