bizzydsm
- 57
- Feb 27, 2003
Mountain Home,
I just put a big 16g on my talon. The installation went smooth exept I snapped my banjo oil feed line bolt in two (which I had to go to the dealership to replace). We fired it up we took it for a drive! The spool up felt strong, and the high rpms felt strong... but not as strong as other cars Ive rode in! I took it to the track and I ran a .2 slower e.t. and 3 mph slower than usual. I can only think of two problems.... First I am only running 13 pounds of boost cause my boost controller is all messed up! Second I run the 1/4mile through my muffler! My exhaust is on the weak side I have a stock down pipe and a 2 1/2 press bent cat back. I think the boost could be part of the problem, but I think that the exhaust is THE BIG PROBLEM! give me some feed back... is my exhaust the problem! If this is my problem Ill problebly end up getting a turbo back 3" system.
