super95awd
- 823
- 7
- Oct 11, 2002
Morgantown,
West Virginia
Ok, 34mm flapper is installed (mind you the o2 sensor housing is ported to 2.5" on the dp side and gasket matched on the turbine side), took it out for a test drive. It creeped far worse than it did before (yes I ported the hell outta the wastegate hole). So I was like, "Hmmmm that's strange." So then I turned off my Profec-B to see how it would fair running off just the wastegate spring. Same results. Hits maybe 14 psi, holds for a second, then begins to rocket to like 22-23. Not good. I went back home to fool around with the wastegate, making sure it was opening properly and such. Seemed to be opening fine. I'm completely stumped. Any ideas guys?
