which wastegate should I use?
flyneagle
71
Jan 31, 2003
ok... im running a 50-trim with of course supporting mods.... but the only part im confused about is the external wastegate.... I was told to get a tial 40mm wastegate, but would a tial 35mm be good enough?...because im planning on running 15-18 psi daily.. and about 25psi when i run it....I have 3inch turbo back exhaust... will I creep with the 35mm?... thanks, nick
Go with the new 38mm Tial. Its alot cheaper and has the benefits of both a 40 and a 35 from what I hear. I have a 40mm with my Green and it can low boost if I want it to. The key on how much boost you want to run is the spring you get with it. I would stay away from teh 35mm just because its harder to run lower boost with.
i dont get it... what benefits are their to the 38mm that the 40mm and 35mm dont have?.. please tell me everything.. i am shopping around soon for one.. thanks for all your help.. nick
It flows more then a 35 mil and costs a hell of alot less then a 40 mil. They no longer even make a 35 mil. The 38 mil is the new small size.
Sean
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
