90AWDTalon
- 877
- 3
- Jan 5, 2003
Everett,
Washington
I've been thinking about getting a Supra SMIC. When I do I'll buy the dejontool upper intercooler pipe. But for the lower pipe I was thinking of a different route.
At my work we have 2.5" hard walled reinforced rubber marine exhaust hose. It is very strong and looks like it will hold boost, and seeing as how it is used for exhaust I would think it would hold up to under hood heat. It is also pliable enough that I could use a single length to go from the compressor outlet to the intercoller. It should connect directly to the intercooler, I have the dejontool 1.75" compressor outlet pipe. I was thinking I could get a 2.5" to 1.75" coupler and have an exhaust shop make me a small 2.5" pipe and weld some beads at both ends, to connect the coupler off the compressor to the 2.5" hose.
What do you guys think?
