tqlla
- 165
- Nov 23, 2002
I am fed up with my oil return line. The first oil return line, had 2 fittings and a rubber hose that connected the two, and the inlet on one fitting crushed when I clamped it down. It was very weak. SO I bought a new return line, 2 fittings and a SS Braided line. The line screws into the fitting.
I have tried everything to get it to stop leaking. I have RTV Sealent everywhere! It stopped for the last 5 or six months, but I retorqued the bolts on my turbo(Did not remove), and the line is leaking again. Its leaking where the fitting meets the SS Line.
I am just about fed up with this line. Anyone have good line, that hasnt leaked or is easily crushed, with 5 ftlbs torque?
Also, when the Manual says 40ftlbs + 60 degrees, they mean torque to 40ft-lbs then turn 60 more degrees? I tried, but I couldnt go past 15-30 degrees before worrying that the stud would break.
