level10a/t93tsi
- 35
- Jul 5, 2002
i have a 93 talon awd but im putting a 6bolt in it. the motor is a 92 5spd motor. i want to put a new engine wiring harnes in it dose any 1 know how much it might be? and do i need to change the CAS harnes to work on the 92 motor. my old motor was a 7 bolt. or should i just get a 92 engine wiring harnes? will the 92 harnes fit my 93 ecu?
is the 5spd motor wiring harnes the same as an auto motor harnes or will i need to change to a 5spd wiring harnes and is their and are the 7bolt motor harnes the same as a 92 6 bolt harnes?
thanks mike
thanks mike
