Front signal lights
Vinnie
273
Aug 29, 2002
Toronto,
On a 2g talon, I've heard that it's possible to take out the orange film that it's used on the front signal lights, making it white.
Has anyone have done it???
yes ive done it, on my 96 talon. you have to open your headlamps (pain in the ass) take off the metal clips, the pain in the ass part is that its all glued together. i used a blow dryer and a razor blade and it still took forever. but once it opened the light falls into about 3/4 pieces, you can take it out then///what i also did was painted the inside of the housing black.:D it looked like the 97+ eclipse!!! very tight, lots of props!!!:D
p.s. carefull with the bolt under the lamp it sux.
Thanx man, that's what I wanted to know.
By the way, do you happend to have any pics, I would like to see what it looks like.
Thanx
Hello Vinnie,
Just wanted to add to the previous information that this topic has been addressed a few times before in the Non-Performance Mod forum, which this likely should reside rather than Engine Performance.
Clearing Headlights
Anyhow, in the best interest of not duplicating somewhat common information please use the search feature .. and good luck with your project.
The Mods may wanna move this to Non-Performance so that you may get additional responses to your question should the results posted above not address your questions.
Later.
thanxs Defiant
Couldn't get a better explanition than that, I'll be doing that in the next couple of weeks.
