Boost Controller?
Dan7040
224
May 22, 2002
SLC, Utah
My mods on my Talon is an Injen Intake System and a Boost Gauge. I just ordered a Turbo XS CBV and the Buschurr UIP, but will boost pressure increase from these mods?? Do I need a Boost Controller before installing these parts?? Thank for any help.
Usually your boost will go up 1or 2 psi from the uip. The t25's shouldnt be pushed above 16psi, and you should be close at around 13-14 after the uip so you should nt need a boost controller
I boost controller should be the best $100 or less that you spend.
Thanks for the advice. I going to buy an elctronic Boost controller but do you think it could hold off a while or would I need it ASAP
