Gm MAF??
TrbTaLoN
74
Aug 19, 2002
If I buy A Gm MAF with a translator does that mean I don't need and S-AFC fuel computer becasue I can do just the same with the translator? DO you control the translator from inside the car or under the hood?
I have the GM maft with a 3' mafs and i have mine just chillin under the hood. Its a little tedious setting it, then driving for a bit, stopping setting driving. But the time is well worth it. You do not need a S-AFC if you have the translator, the AFC will help to further adjust the ratios with smaller incriments, if your into serious tuning, but its not needed. The Translator could be run into the car, but after you set it, its just gonna be in the way.
