7 bolt main bearing cap tourqing specs
BLACKWIDOWDSM
Jul 13, 2003
Can someone please tell me what sequence and how many pounds to put on the main bearing cap bolts.( the bridge that holds the crank in). My seup is a 96 GSX 7 bolt and all its standard...The bolts are stock and i will be using 20-50w oil to lube. Thanksin advance....PLEASE let me know this is what i lack to get my engine in.:thumb:
I am not sure the TQ specs, but why are you going to use 20w-50? You shouldn't have to. 10w-30 would be just fine. People who use 20w-50 are usually trying to cover up leaks or other small problems inside their engines. 20w-50 is a bit overkill, but peoples opinions may differ. Oh, and I am sure you know, but make sure to use regular (non-syn) for your first oil change or so. Good luck with the build up.
I think he means that He'll be using 20w-50 to lube the bolts while Torquing.
BTW, that TQ spec is 18 ft/lbs + 1/4 turn
Good luck,
Originally posted by Defiant
How did you get that far into an engine without a manual? Grab a Chilton's at Pep Boys. Mine's not in reach, or I'd tell you.
No kidding.
The spec I quoted earlier, 18ft/lb + 1/4 turn, was from a Chiltons manual. I looked for my Mits Tech manual, to verify, but couldn't find it, must be at the shop.
Well I have the chiltons but I wanted to do it today or tomm. but I couldnt find the chiltons...finally found it....but half the pages are gone...luckily the engine stuff is still there....thanks guys
