help with install of 16g in 1g auto
Cnock
106
Feb 28, 2003
Trenton, Michigan
i spent all tearing my dsm apart to put in my new b16g from slowboyracing and a ported 1g mani i have from a 5speed. well everything was fine till i started to put the lines back on. the oil feed line to head was fine but when i tried to put the other lines on it the banjobelts from the lines were to small? WTF? is this because the housing is bigger? has anyone encountered this?
I assume the 13g uses different banjo bolts for the water lines. You'll need to get the bolts, crush washers, and water lines from a manual trans 1g. You may need the IC piping as well I'm not sure. BTW you really should buy a SS oil feed line when you get a new turbo.
i got the ss line will i really need all that or just the bolts?
