speeddro18
- Jul 7, 2003
I NEED TO KNOW IF THE STAGE THREE BUSHUR RACING ENGINE WILL HOLD A T3/T4 60-1 AT FULL BOOST IT SAYS THAT IT WILL HANDLE UP TO 700WHP CAN ANYONE HELP ME
THANK YOU DAVID
THANK YOU DAVID
Originally posted by speeddro18
actually i have evrything but the nitrous kit which i am buying next week i have pics if u wanna see
Originally posted by 98talonAWD
And to all you people that bi*** at others because you put all this money into your DSM and hate life because you DONT TUNE YOUR CAR RIGHT.. don't come on these forums and bi*** at everyone just because they are doing things the RIGHT way and are probably faster with there stock car than you are with your modded one!
So if you don't have an educated response... shut up and log off because you have nothing to add to this forum.
_________________________
It's Just a lil Talon boys! Why won't you play with me?!?!?!
OL
OL Indeed
First off, buy a 4 layer metal head gasket, prefferably the RalliART head gasket! (they are the best)Second, setting up a 2 stage or SECONDARY NO2 spray is easy... just don't go overboard with it. Remember... Nitrous isn't Explosive!!! Nitrous makes the molecules in your fuel system smaller, causing the gas to burn better across the cylinder. But more air into your engine makes you A/F ration lean out causing the engine to take a nose dive on you! So all you need to do is add more fuel into your engine and your set!
And to all you people that bi*** at others because you put all this money into your DSM and hate life because you DONT TUNE YOUR CAR RIGHT.. don't come on these forums and bi*** at everyone just because they are doing things the RIGHT way and are probably faster with there stock car than you are with your modded one! So if you don't have an educated response... shut up and log off because you have nothing to add to this forum.![]()
Thanks
TIMMAY
!!!! You are talking about educated responses and look at yours! First off if you knew anything about nitrous then you'd know it's N2O, second of what the #### is an A/F ration? Ratio maybe? And that explanation of how nitrous works is pathetic... Nitrous simply makes more power because it adds more oxygen to the motor... Now sure adding more fuel to the mixture would help things out, but again if you knew anything you'd know that just adding fuel won't save everything... You need to pull timing and run colder spark plugs or you'll destroy plugs which in turn can destroy motors... Please don't offer your advice unless you really know what the hell you are talking about, and aren't just a bench racer....
Originally posted by hardrive07k
It seems there always has to be a dick in here somwhere, if your not gonna awnser the F%$#^*& question, GET OUT, go be a dick to your your boyfriend or something
OLOriginally posted by Tevenor
Thread closed for the unbelieveable bench 'tooning' going on.
