turbo swap.....need answers fast
DSM_Kmart_Laser
k i need answers quick 4 this one......i need to know what needs to be removed from the turbo 4g63 to put the turbo into the n/t 4g63, and also whatever else will need to be purchased to do this. thanks guys
just about everything...the whole engine is different and is set up for f/i where as the N/T engine is set-up for NA. Differen't compression, rods, pistons, cams, head...exhaust mani, intake mani, throtle body, ecu and lots of wiring, ic, turbo, injectors, fuel rail, uhh yeh...even though they are both using the same block they are very, very different and it is not an easy swap
