2-0turbo
- 787
- 5
- Mar 13, 2002
Lynchburg,
Virginia
Hey all. I am in the process of a 6-bolt rebuild and considering a 4G64 crank with Eagle rods and Ross pistons. JE and Ross (through Magnus) make the pistons with the wrist pin moved to accommodate the longer stroke. I am very interested in this upgrade, but I want to have it reliable long term.
By moving the wrist pin up 6mm, on most pistons this begins to interfere with the lower oil control ring. The guys that stroke Ford 302's to 347's report high oil consumption problems after doing this mod because of the wrist pin/oil control ring interference.
I emailed Magnus to see, since their pistons are "custom" designed, if they addressed this issue by moving the lower oil control ring up some. I got no answer and hoped if anyone here was using these Magnus pistons, they could tell me if this was the case.
Does the wrist pin on the Magnus/Ross 9.0:1 Stroker piston interfere with the lower oil control ring? Thanks.
Swordfish, how long have you had the settup in for? Have you noticed anything about oil consumption? I'm sure that Marco prolly knows what hes doing, and with the proper support and rigth rings Im sure it would even be ok to have that much gap....but then again noones really been driving these everyday for a while now as they are fairly new!
