lowridin2g
- 904
- 2
- Sep 5, 2002
Pembroke,
Massachusetts
i did a leak test recently after attempting to replace my o ring in my throttle body. i leaked air out the top of the greddy bov at 5 psi. its already adjusted pretty tight and i have the nut tightened down pretty good. i tightened the nut more while it was leaking and slowly it got quieter, leaked less. should it leak like that? i did strip it out a couple weeks ago and had to retap it to a size bigger. would some teflon tape on the set screw help it to not leak out the top? or is this just normal?
