K&N Filter
Yes, it needs to be cleaned from time to time. The instructions you received with the filter should have explained this, but nobody reads those, right? ;)
The lazy way out would be to purchase a K&N "recharge" kit, which just includes a bottle of cleaner and a bottle of oil. Do a search on here, I'm sure you'll turn up the Home Depot answer as well (I'd know what's in the cleaner, because all my go-fast parts come from Home Depot, but I got a cleaning kit with my FIPK so never bothered researching it).
You clean any major deposits off the filter with a brush, spray it with cleaner, then flush it under cold water (making sure you run the water the opposite direction the air flows; for an FIPK, for example, run the water through the inside of the filter toward the outside). Apply the oil evenly to each ridge and valley in the filter. Ta-da, clean filter.
By the way, this isn't exactly "Advanced Performance", and should have been posted in the General/Newbie forum, methinks.
    • eclipsemf
