16 g rebuild???
Happy
Banned Member
404
Feb 1, 2003
Ok im lookin at this turbo on a site and if i can get it cheap enough, is it woth it?? It needs a turbine housing, and the seal's are shot he says. So will the housing of my 14b fit on?? And well if i had it od it shouldnt be much to get it done over. As well do u guys no of any where to get rebuild kits, for the 16g???
200 Canadian and will the 14 b housing fit on the 16g?? I thought i read somewheres where u could buy the 16g cartridge and put it into the 14b housing??
just went through my b16g-looks as if the housing would fit from a 14b but it wouldnt clear the compressor wheel.so i guess if you put the wheel and housing on it-but then why not just keep the 14b.anyway hope that helps.
The 16g and the 14b both use the same compressor housing, but it has to be machined in order to fit on a 16g. Therefore, you cannot use the same housing, unless you have it machined, and once you have it machined, you can't use it on a 14b again.
Both 14b's and 16g's will mate up with the standard Mitsu 6cm^2 and 7cm^2 turbine housings.
...Kyle T.
Yes i phoned forced performance.com and they told me it will fit no problem!! Fot the difference in the 6 and 7 cm couldnt u just port that a little???
Yes, porting helps. A ported 6 cm housing can flow good, about as good as a stock 7cm housing, but not as good as a ported 7 cm housing.
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
