WhipmastaFlex
- 561
- Jan 2, 2003
first off: rebuilt motor 3500 miles, idle set at 1000rpm, 13-14in/hg vaccum, running webcams street grind
ever since i put the new cams on (3500 miles), i have had no driveability or idle problems. the past few days, my car has lost about 2-4 in/hg vaccum at normal idle. i turned the biss up a alittle (300rpm) to idle at 1250/1300rpm, and it went back to 13in/hg of vaccum, whereas before that would yield 15-16in/hg of vaccum. now my idle is all over, anywhere from 800rpm to 1500rpm. vaccum goes from fine to crap at varying stop lights. it is almost not driveable with the A/C on (8 or less in/hg). i checked every conceivable vaccum hose and all other hoses. the biss screw and o-ring are still in tact as well. i recently had a CEL pop up on me, which i usually pay no attention to, but this happened around the same time. autozone is a bunch of lazy SOBs and will not read my CEL, nor speak english. what else could be the cause for this vaccum/idle leak? i have fidanza cam gears, is there anyway that adjusting the cams would improve vaccum? thanks in advance
