Monster Thrust turbo bearing Center or Not?
irn__man
256
Oct 8, 2002
New Orleans, Louisiana
Which of these two turbo center sections would be the best to go with? One is a Mitsi center section and the other is the Monster Thrust turbo bearing Center. Specs are below:
-Garrett 50 trim with Mitsi TD06 20G style compressor housing
-TD05H 7CM turbine housing with TD06 or TD06H Turbine Wheel
-Internal Waste Gate
-Monster Thrust turbo bearing Center or Mitsi Center
Basically the question is, Should I go with the the "Monster Thrust turbo bearing Center " or Not?
thanks in advance
iron
Originally posted by GrocMax
Sounds like one of the many FP copycatters out there.
Agreed, but what are the advantages of the Monster Thrust turbo bearing Center?
iron
