Need Help Fast!!!!!!!!!!!
snipe99999
301
May 13, 2002
We installed my downpipe and high flow cat and after starting up the car there are some major problems. Once I start driving the horn will not shut off and the lights will not turn off either. Also the radio is now asking for a code. The car does have a factory alarm. I need some help really fast because I can't drive it like this.
did you reset your battery or something. The fuse for the alarm should be on the engine bay along the firewall somewhere. Thats where a lot of them are.
for the radio code you have to call the dealership, they will probably try to tell you that you have to bring in your radio so they can plug it into the machine for 35 bucks but i got into a heated discussion with my dealership and after all that all they need is one of the numbers on the sticker that is on the radio. it can all be done over the phone. i dont knwo about the horn and all that haha pretty wierd.
After doing some more testing we found that once the car is started everything seems to be working. It is when the car is in the accessory position the windows won't work the headlights will stay on even if I turn them off the door locks won't work. If I start up the car and the stuff still does not work as soon as I rev the engine just a little bit everything starts to work.
