Cyclone manifold: MBC-controlled
tsi_turboawd
474
Jun 20, 2002
Las Vegas, Nevada
For now i just have the actuator for the butterflies directly hooked up to the Intake manifold nipple. So the butterflies open up right when boost kicks in. I want them to open at a certain boost level.
What if i hook up an MBC set @ 6psi between the actuator and intake manifold? wont that work?
You could, however, you still wouldn't want them to open up when you hit a certain amount of boost. They're supposed to open up around a certain RPM, that way you get the most out of your torque and hp curves as possible.
Well it isnt worth it.. but if you already have the cyclone on with the motor keep it and get it working right! ..im gonna have to find another MBC for the cyclone manifold
oK, SO HAVE A MSD IGNITION AND HAVE A RPM CHIP NOT OPEN A SOLENOID TILL 4000 rpm regardless of whether the mbc is open or not.
edit: caps lock makes me look like I have a 50 IQ
