13secGST
- 1,108
- 2
- Dec 1, 2002
San Luis Obispo,
California
Ok. Basically I'm going to buy a big16g maybe by Friday but definetly before next friday. I've been told by Mike at DSS that I should get a one with a clipped turbine.
I have also searched here and heard a lot of negative stuff because it only reduces the effieceny of the wheel and takes longer to spool while adding ever so slightly on the top end.
While researching I found that people with TDO5 20g's clipped went from 116mph - 121mph in 1/4...really I'm not big on the 1/4, I'll be running pump gas 95% of the time and want a really good street car. Thats why I'm going with the big16g.
What do you guys have to say...is it worth it on a big16? Since I basically want a steet car I feel kind of negative about it cause my mid range is also very important. Also I heard that a clipped big16 can boost 26psi vs. 23psi on an unclipped, is that true? I thought the wastegate opened before that. 3 more psi could mean a lot in the hp arena as long as the turbo is still effiecent. But I also have a VP FMIC kit on its way...soo
Please nobody say...its bad or its good, I am looking for opinions on why it is bad and hopefully people that have driven cars with both could inform us on the pros and cons of each vehicle.
