Thower
- 41
- Mar 10, 2003
i have a 98' gsx and i am replacing thetop end with a 1g, will the throttle body from a 1g wokn my 2g?Follow along with the video below to see how to install our site as a web app on your home screen.
Almost 6 years later!!! In 6 years you havent learned how to use the search feature. Or even VFAQ Site - Visual Frequently Answered Questions.
Bolt on the 1g TB and connect the sensors as you normally would. Usually with this mod we eliminate all the vacuum lines at this point and cap everything off.
that must be a record for the amount of years it took.. check this postThat would be incorrect. You have to run 2 vac lines off of 1 nipple on the 1g tb because one of the vac lines off of the 1g tb we cant use. One nipple on the tb is unused. We cant use the 90 tb. Just search it. I promise. You will come up with many threads about the subject.
Thanks for the correction, i was just stating though the non-vacuum way of hooking it up, which would relatively had been simpler, but yes you are right about the 1 less nipple.
