1G 1G upper IC pipe?
TalonTsiAWD94
119
Apr 24, 2002
hi i was wonderin which is the best Upper IC pipe for the cheapest price....I'm plain on getthin an 2G TB elbow so does tha mean i have to get a pipe for a 2G...I have no clue......please help.....i also have a stock IC...and i also have ABS......please help.....thanx:)
no, the 2g tb elbow is an upgrade in contrast to the 1g. you still need a 1g uicp. the 1g uicp kit usually comes with the 2g throttle body elbow. it is a decent mod that will get you a hp gain. you re-use your blow off valve that you have on your car now. the kits usually come with all of the clamps and couplings as well. i use the buschur racing uicp it is 2.25" mandrel bent. it is more than sufficient. some uicp kits are 2.5". it all depends on what you want & what you need.
do i have to look for a IC pipe tha has a certian size for the stock IC?
I have made my own for $30 in parts. Its easy, here is the link on how to do it. If you don't have a welder, take it to your local muffler shop to weld it for you. You will need a 2G elbow of course. This is one of my favorite sites when I got into DSMs a few years back. Click on products and off you go.
http://www.myzero.com/
ok i found an upper IC pipe at a good price or atleast i think its good you tell me.....UICP-1g-2.2b (2 1/4" ABS model shown) @ http://www.dejontool.com/ what do yous think about this one....its $195 should i get it?.....
Also what about this intake pipe...CIP-2/1gA - 2g MAS to 1g Car Compressor Intake Pipe at dejontool.com..... but i was wonderin would i have to use an 1G filter or a 2g?......helo
Dejon Tool makes some nice stuff that alot of dsm'ers buy. Like someone else said they are all pretty much the same it's up to you to decide which one you like.
Later,
