Login
Go Back   DSMtuners > DSM Forums > DSM Tech > Bolt-on Tech
Welcome to DSMtuners
Bolt-on Tech: 4G63 intake, exhaust, intake manifold, ignition, fuel system, cooling, etc.
Reply
LinkBack   Thread Tools
Old 05-29-2012, 07:28 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
markf671's Avatar
Tech Posts: 67
Classifieds Rating: 0
Reputation: markf671 is an unknown
Real problem with broken manifold bolt.
As I was replacing my exhaust manifold... I snapped one bolt, it snapped halfway into the hole.... So I searched the forums, ended up buying a extraction bit.. Drilled a little hole for the extractor, tried to turn it,it wouldn't budge! So I bought a the extractor set from autozone did the samething.... I drilled it with a regular bit then tried using the left handed bit... Still no luck! So now I got one side of the bolt drilled out and some of the bolt just hard to get!
I was thinking of just drilling a new hole and tapping it for the new oem stud I bought.... Or can the mess I made be saved? That whole time I was soaking it with PB, how would I go about drilling a new hole? What type of bit do I need? If I go that route.... Any other solutions would be very helpful! I was even thing of towing my car to the machine shop...
Thanks DSMers!
Mark
____________________________
Mr. Flauta 98 gsx
mark post as helpful recommend reputation points    Reply With Quote
Old 05-29-2012, 07:57 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
AwD4g63TsI's Avatar
Tech Posts: 120
Photos: 7
Classifieds Rating: 8
Reputation: AwD4g63TsI is more helpful than not
I would do 1 of two things now that you know an extractor won't work
1. drill out the rest very carefully all the way through, centering the drill as closely as you can. The sides of the broken stud should crumble apart(might need a little coercing with a small pick or something similar). An air gun can blow all the pieces out.
If you are dead set on doing this, you can also take a vary small carbide bit and cut away the inside of the old bolt to try and save the threads on the head.
2. I would recommend this method as it's less hassle IMO. Drill the old stud out with a drill one size larger. Then use a helicoil to get the hole bigger, re-tap, then install the new inserts. You'll be able to use the exact same size stud after this and no trip to the machine shop. You just have to buy the right size helicoil kit. It's very easy to do if you haven't done it before. Good luck.
View photos of this member's car
Old 05-29-2012, 08:11 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
markf671's Avatar
Tech Posts: 67
Thank A lot bro! I will take option #2! It sounds easy enough... Do you know the size of the oem stud by and chance? Thanks again!
Mr. Flauta 98 gsx
Old 05-29-2012, 08:40 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
biglady112's Avatar
Car: 1947 Dodge Pickup
Tech Posts: 816
Classifieds Rating: 4
Reputation: biglady112 is extremely helpful and trustworthybiglady112 is extremely helpful and trustworthy
M8x1.25
4G61 powered 1947 Dodge Pickup
Old 05-30-2012, 04:56 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
markf671's Avatar
Tech Posts: 67
Thank you so much guys!
Mr. Flauta 98 gsx
Old 05-31-2012, 08:11 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
markf671's Avatar
Tech Posts: 67
One more question? What drill bit do I get? Type and size? Thanks, sorry for asking
Mr. Flauta 98 gsx
Old 05-31-2012, 10:50 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
Fejery4491's Avatar
Tech Posts: 137
Classifieds Rating: 10
Reputation: Fejery4491 is an unknown
Go get yourself some m8x1.25 helicoil. It should tell you what size drill bit to use
Old 05-31-2012, 07:13 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
markf671's Avatar
Tech Posts: 67
Thanks Bro, I finally drilled out that freaken stud... I boought the 8mx1.25 thread repair inserts.. It didn't come with instructions! Do I tap it with a 8m tap? or just insert the new thread?
Mr. Flauta 98 gsx
Old 06-02-2012, 07:10 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
markf671's Avatar
Tech Posts: 67
OK! Thanks again everyone! It was easier then I thought... bolted it up! gonna test it tomorrow for boost leaks! Boom!!!!
Mr. Flauta 98 gsx
Old 06-02-2012, 07:13 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Supporting Member
BurrowZ's Avatar
Tech Posts: 459
Photos: 2
Classified Ads: 1
Reputation: BurrowZ is more helpful than not
Quote:
Lol.. if your exhaust manifold has a boost leak.. you've got issues.
Chris
Cursed Auto 97 GSX
Old 06-21-2012, 07:24 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
markf671's Avatar
Tech Posts: 67
No leaks! On mani but found a big one on the j pipe.... Fixed now! Thanks guys!
Mr. Flauta 98 gsx
Reply
Bookmarks
Thread Tools
» Recent DSM Videos
1gb AEM wastegate hood dump 2step
» Recent DSM Photo
Post your banner here
» Current Poll
How many times have you been to the Shootout?
1 - 38.28%
111 Votes
2-5 - 43.45%
126 Votes
6-10 - 10.69%
31 Votes
11-15 - 2.76%
8 Votes
16-20 - 4.83%
14 Votes
Total Votes: 290
You may not vote on this poll.
» Online Users: 485
184 members and 301 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
