O2 elimination??
A. Van
346
Jul 1, 2002
Why eliminate the O2 senser?
How do you get the computer to work with the O2 eliminated?
Are there any procedures that need to be done to get the exhuast or computer to work after eliminating the O2?
Doesn't the O2 check to see ing your running lean or rich?
You can't really eliminate the O2 sensor. The "O2 Eliminator" stuff you read about is really "O2 sensor HOUSING elimination" as in, replacing the heavy and restrictive O2 sensor housing with a free flowing tubular exhaust section. The actual sensor is still there.
it puts the o2 sensor housing on the outside of the downpipe. it just eliminates the o2 sensor housing from being actually on the downpipe.
holly crap you made something simple sort of confusing.
how can the o2 sensor housing be on the outside of the downpipe? A o2 eliminator complete eliminates the o2 housing doesnt it?
Originally posted by ChicagoGSX
All O2 eliminators do is replace the stock cast O2 housing with a high flowing unit made of tubular steel. The O2 sensor is still used, w/o an O2 sensor the car would run very rich.
omfg..just disregard everything said in this thread except for what chicago says..geez
